Clearing congesiton statistics for a port failed on hardware.
This problem is usually due to a failure of accessing a hardware register. The hardware may be in a bad state. The error message gives the detail of the failure. The problem usually can be resolved by retrying the operation or power-cycling the switch or the card in the slot.
Error
Failed to clear congestion statistics for port %slotPort%: %errMsg%
| Name | Type |
| slotPort | SlotPort |
| errMsg | String |
